Isolation amplifier circuit diagram
Source: InternetPublisher:宋元浩 Keywords: Isolation amplifier amplifier circuit diagram Updated: 2020/09/19
The front stage of this circuit is a common emitter circuit with strong negative feedback, and the rear stage is an emitter follower, so that the input impedance is |Z1|=3.6 megohms and the output resistance is only |Z2|=250 ohms. The operating frequency of the circuit is 20~20000Hz, and the distortion factor is less than 0.5% at an output voltage as low as 2.5V.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Analysis of the basic principle of measuring resistance by bridge method
- Types and structures/characteristics/functions/implementations of smart sensors
- What are the parts of the fpga design process
- How to calculate the value of capacitors in parallel?
- What is a D flip-flop and how does it work?
- How does RCCB work?
- How to build a triangle wave generator using an op amp and discrete components
- An example of proportional integral circuit diagram
- Digital number selection machine
- TDA2030A power amplifier circuit diagram
- TDA2009 power amplifier circuit diagram
- TDA1518Q power amplifier circuit diagram
- TDA1516Q power amplifier circuit diagram
- TA7282AP power amplifier circuit diagram
- TA7240AP power amplifier circuit diagram
- TA7230P power amplifier circuit diagram
- STK459 power amplifier circuit diagram
- STK443 power amplifier circuit diagram
- SK4332 power amplifier circuit diagram
