Differential bridge amplifier circuit diagram
Source: InternetPublisher:D先生 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/12/07
The LTC2050HV is a zero-drift operational amplifier available in 5-pin or 6-pin SOT-23 and SO-8 packages. The LTC2050 operates from a single 2.7V to 6V power supply.
The following is a circuit diagram of a differential bridge amplifier.
![Differential bridge amplifier circuit diagram](http://www.eeworld.com.cn/circuit/upload/e1e995e40da2d573fc2b1e852eb6ff76/984ce939359d226e1f1f1509fd3f95c1.jpg)
The LTC2050HV operates from a 2.7V to ±5.5V power supply. Current consumption is 800µA, and power-down functionality (active low) is available on versions of the device in 6-pin SOT-23 and SO-8 packages. Although the LTC2050 is small in size, its DC performance is not compromised at all.
Typical input offset voltage and offset drift are 0.5μV and 10nV/C respectively. Nearly zero DC offset and drift are supported with power supply rejection ratio (PSRR) and common mode rejection ratio (CMRR) greater than 130dB.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- ISO113 circuit that can reduce power consumption
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Detailed explanation of 5v charger circuit diagram
- Miniature polarity reversal power supply using MAX1721
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Production of backup power supply for cordless phone
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
