IC4069 simple infrared remote control switch circuit diagram
Source: InternetPublisher:aerobotics Keywords: Power supply other power circuits Updated: 2020/02/20
4069 simple infrared remote control switch circuit diagram. Nowadays, infrared remote control transmitters such as TV, VCD, and VCR are more common in households. This circuit is designed for their performance, allowing the remote control transmitter to play another purpose: emitting infrared signals and controlling lighting fixtures with a control distance of >8 meters. .
Circuit principle: This circuit is shown in Figure 1, which is an infrared control switch circuit mainly composed of an infrared receiver and IC4069. The infrared receiver outputs high level when it is static. When receiving the infrared pulse signal from the remote control transmitter, the first pin of the receiving head outputs a low level (pulse signal). After ICa is shaped, amplified, and inverted, the negative pulse signal is obtained, which is then detected by D5, C4, and R3 and sent to ICb with a delay (reaching the threshold voltage of the inverter), causing ICb to output a low level, and then the voltage at C4 is passed through R3 discharges, causing the ICb input terminal to be lower than the threshold voltage of the inverter, and the ICb output terminal returns to high level. In this way, every time the infrared transmitter is pressed, a negative pulse signal is obtained at the output end of IC6 to trigger the bistable circuit composed of ICc and ICd, causing the bistable circuit to flip and output H or L level, through R8 Control the conduction or cut-off of the one-way thyristor, and then control the lighting and extinguishing of the lamp.
The 220V AC power is rectified and stepped down by D1~D4, R1 and C1 to provide +5V DC voltage for the circuit.
Debugging and Precautions: As long as the components are installed correctly, you can power on and measure the voltage of the TC4069 pin, which is generally around +5V. If the voltage is too low, adjust the resistance of R1 appropriately. The empty consumption of this circuit is extremely small, and the measured power consumption is less than 1/2W. Note: The circuit board has high voltage, so be careful when testing to prevent electric shock.
Component selection: The infrared receiver has a high DC internal resistance and an operating voltage of +5V (see Figure 2). The one-way thyristor SCR should have the same power as the selected incandescent lamp to prevent over-current breakdown.
![IC4069 simple infrared remote control switch circuit diagram](http://www.eeworld.com.cn/circuit/upload/c8ce03c44bb8816fe2fa94e2e1efc233/c362bc5b117175ef9f452bbd7ed54758.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How to Make a Soft Latch Circuit
- Build a simple buck-boost regulator and test it on a breadboard
- Energy-saving motorcycle rectifier regulator
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Dual forward converter schematic diagram
- A novel and practical DC low voltage stabilized power supply
- USB power socket using the car battery
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
