Clamp amplifier AD8037PIN diode driver circuit diagram
Source: InternetPublisher:ohahaha Keywords: amplifier circuit diagram driver PI Updated: 2021/01/19
The circuit operates at frequencies up to 10MHz, has excellent switching performance, and has a total propagation delay of 15ns. By changing the gain or clamping element voltage, the output voltage and current can be adjusted to suit different applications.
The clamp amplifier AD 8037 was originally designed to drive an ADC and provides a clamp output to protect the ADC input from overdriving. The configuration shown in the figure uses a pair of AD8037s to drive PIN diodes.
- A very convenient small power supply circuit to share
- How to Make a Soft Latch Circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- Boost drive circuit composed of RT8450
- 0.7~24V continuously adjustable current limiting power supply
- Car Audio Power Supply
- A low-cost, high-reliability battery charger for electric vehicles
- High performance broadband GaN power amplifier
- Detection circuit diagram of AC side voltage Us based on SG3525
- High-end four-channel mixer
- TDA2030A subwoofer circuit diagram
- Ultrasonic proximity sensor circuit
- Clamp amplifier circuit diagram
- LTC2057 Differential Thermocouple Amplifier Circuit Diagram
- An ultra-high-precision level conversion circuit diagram
- An FM transmitter overvoltage protection circuit diagram
