LTC2057 Differential Thermocouple Amplifier Circuit Diagram
Source: InternetPublisher:aerobotics Keywords: Amplifiers power supplies and other power circuits Updated: 2021/08/02
The LTC2057 is a high-voltage, low-noise, zero-drift operational amplifier that provides accurate DC performance over a wide supply range of 4.75V to 36V or 4.75V to 60V (for the LTC2057HV). Offset voltage and 1/f noise are suppressed, allowing the amplifier to achieve a maximum offset voltage of 4μV and a DC to 10Hz input noise voltage of 200nVP-P (typ). The LTC2057's self-calibrating circuitry enables low offset voltage temperature drift (0.015μV/ºC maximum) and zero time drift. In addition, this amplifier has excellent power supply rejection ratio (PSRR) of 160dB and common mode rejection ratio (CMRR) of 150dB (typ).
![LTC2057 Differential Thermocouple Amplifier Circuit Diagram](http://www.eeworld.com.cn/circuit/upload/6dfa776eba0b7a93dc535293e0aef284/99b5c31d6786b9b5dd72d0c89578b1ca.jpg)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- The basic principles of power supply design. What are the key components of a power supply?
- Introduction and principle analysis of switching regulated power supply
- Step-down power supply for driving relays
- ISO113 circuit that can reduce power consumption
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Op amp power supply decoupling bypass measures
- Boost drive circuit composed of RT8450
- Constant current charger using light emitting diode as voltage regulator
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- 90V/10A high power amplifier
- Voice compressor circuit
- TDA2030A subwoofer circuit diagram
- Clamp amplifier circuit diagram
- Cascade MMIC amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Basic Op Amp Differential Amplifier
- An FM transmitter overvoltage protection circuit diagram
