Switching power supply output part circuit diagram
Source: InternetPublisher:司马缸砸光 Keywords: Switching power supply circuit diagram WIDTH Updated: 2020/08/31
The 12V voltage is unstable. You should check the output part of the switching power supply first , as shown in the figure. Check that the secondary winding of the switching transformer and VD4 are normal, and that the inductor L2 has no weak soldering. The parameters of filter capacitors C22 and C23 are both 1000pF/16V. Use a capacitance meter to measure C23. It is basically normal (the capacity drops slightly), but the capacity of C22 drops to less than 80μF. The reason for comparing C22 and C23 is that the main power supply of the machine Installed in the base of the monitor, the space is very small and the heat dissipation is poor. C22 and C23 are both close to the 12V rectifier diode (especially C22 is closer). After being baked, the capacity decreases, making the 12V load capacity worse, and thus This failure occurs. Although 5V and 3.3V originate from 12V, the instability of 12V does not drop below the limit supply voltage of the 5V and 3.3V converters , so these two voltages remain normal, thus masking the nature of the fault.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Using Lead-acid Battery as Power Source for Walkman
- What kind of circuit is a voltage regulator circuit?
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- Low cost and high performance LED constant current power supply
- A simple positive and negative power supply circuit
- USB power socket using the car battery
- megaphone circuit
- LA4510 power amplifier circuit diagram
- LA4480 power amplifier circuit diagram
- Solar water heater water automatic control circuit diagram
- HA1384 power amplifier circuit diagram
- AN7168 power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Blind multimeter circuit diagram
- Field output circuit: TA8403 circuit diagram
- LinkSwitch-PL series LED driver circuit diagram
