Practical circuit diagram based on LT3468 dual output boost LED driver
Source: InternetPublisher:同住地球村 Keywords: LED driver boost type practical circuit diagram WIDTH Updated: 2020/11/10
This circuit is a practical circuit based on the LT3486 dual-output boost LED driver . It drives two strings of LEDs with a constant current of 100mA, and the LED voltage is up to 36V. This boost converter uses a small voltage sense resistor in series with the LED string and PWM dimming MOSFET and has high efficiency. The dual-channel LED driver drives two LED strings of 20 LEDs over a battery voltage range of 9 to 16V while keeping the maximum switching voltage below the IC's 42V rating.
- TEC laser diode driver circuit
- Example of LED AC drive circuit
- Audio level LED and digital dual display circuit
- LED acceleration and deceleration motion display composed of CD4017
- Delayed gradual lighting with protection function
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Design and production of digital number answering machine
- Infrared remote control device circuit
- AC and DC dual-purpose flash light
- Remote anti-theft alarm
- Hardware circuit diagram of ultrasonic range finder
- High voltage pulse width modulation (PWM) LED driver controller circuit diagram analysis
- Programmable gain amplifier circuit diagram
- Subwoofer crossover amplifier circuit diagram
- SPT1141/1151 multi-function switch controller circuit diagram
- AC 220V to DC 600V switching power supply circuit diagram
- Constant voltage current limiting charger circuit diagram
- MK5087+TWH630 remote control transmitter circuit diagram
- Electric bicycle Jiateng charger circuit diagram
- 6-digit LED driver circuit
