Corridor light control circuit diagram
Source: InternetPublisher:武林萌主 Keywords: Control circuit diagram WIDTH Updated: 2021/04/28
This circuit controls the on/off cycle of light through the CD S's photocell and turns it off after a preset time lag. This light will only turn on when the CD S photocell is in the dark. The time it turns on is determined by the 555 circuit . The time is determined by R1 and C1, and the value shown indicates that this time is approximately 820 seconds.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- One-way rotation circuit of motor controlled by contactor
- IGBT modules block overcurrent by controlling the gate
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Ultra-short wave item left behind reminder alarm
- LA4475 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Differential amplifier circuit diagram schematic diagram
- Nickel-cadmium battery charger circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Comparison circuit diagram of LM324
- PLC circuit diagram of CNC machine tool
- Circuit using NCP1216 to drive LED
- LinkSwitch-PL series LED driver circuit diagram
