LinkSwitch-PL series LED driver circuit diagram
Source: InternetPublisher:containsmachine Keywords: LED driver circuit diagram WIDTH Updated: 2020/08/14
Powerint's DER322 reference design uses the LinkSwitch -PL series LNK460VG device. It is the industry's first LED driver that can replace 100W A19 incandescent lamps . It uses a single-layer PCB, has the characteristics of low cost, low component count and small size. At 230V AC , the efficiency is greater than 93%, PF greater than 0.9, 230 V AC ; THD less than 20% at 78 V LED, integrated package protection and reliability features, automatic recovery from thermal shutdown. This article introduces the circuit diagram of a 5W 15V LED driver using the LinkSwitch-PL series to replace the A19 incandescent lamp .
- TEC laser diode driver circuit
- LED acceleration and deceleration motion display composed of CD4017
- USB powered portable light
- LED Signage with RS232 Port Operation Guide
- One of the water full alarm circuits
- Resistor value selection circuit
- One of the bead-type emergency light circuits
- Automotive LED driver circuit diagram using LT3486
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent lamp dimming circuit composed of thyristors
- AN7178 power amplifier circuit diagram
- High voltage pulse width modulation (PWM) LED driver controller circuit diagram analysis
- Programmable gain amplifier circuit diagram
- Sensor lighting LED driver circuit
- AC voltmeter circuit composed of milliammeter
- 5V-USB charger circuit diagram
- Electric bicycle Jiateng charger circuit diagram
- Field output circuit: TDA3654 circuit diagram
- Positive temperature sensor and coefficient resistor circuit diagram
- Circuit diagram for driving 4 white LEDs based on charge pump
