Positive output mono circuit diagram
Source: InternetPublisher:newlandmark Keywords: Mono Circuit Diagram WIDTH Pulse Updated: 2020/01/11
The timer is triggered by a negative pulse and will produce a positive output pulse. The width t of the positive remote control output pulse is 1.1 in a short time. Vcc is 4.5-16V at 3-10mA.
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Single-ended Class A amplifier using gallstone composite tube design
- 6N5P tube direct-coupled single-ended amplifier
- Homemade multi-sound effects sound system
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- Audio power amplifier circuit powered by a single power supply using LM1875
- LM4903/4905 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- LM4906 Audio Power Amplifier Circuit
- LM4819 high gain audio amplifier circuit
- LA4507 power amplifier circuit diagram
- Solar water heater water automatic control circuit diagram
- AN7178 power amplifier circuit diagram
- 75 watt audio amplifier circuit diagram with load line protection
- Principle circuit diagram of three basic working modes of non-isolated switching power supply
- MJE13005×2 electronic ballast circuit diagram
- MAX9489 charging circuit diagram
- Electric fan induction braking circuit diagram
- The ever-changing sound and light analog controller circuit 02
- LinkSwitch-PL series LED driver circuit diagram
