Interface circuit diagram using black and white TV as display terminal
Source: InternetPublisher:吃掉星星 Keywords: Interface circuit diagram display terminal black and white TV WIDTH Updated: 2021/02/24
This interface circuit is added between the standard video signal output of the computer and the TV, and can amplify the standard 1V (peak-to-peak) video signal to 3V (peak-to-peak).
T1 and T2 form a negative feedback amplification circuit with a wide frequency band range. The circuit amplification factor is mainly determined by the ratio of R1 and R8.
ck="window.open(this.src)" alt="Click to see larger image" />
- Why should RS-485 transceivers be terminated? How to terminate?
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- How to use CAN protocol in Arduino
- FMA9901A FM broadcast dedicated antenna
- Production of a FM wireless microphone
- SB-200BRX superheterodyne receiving circuit
- Cordless phone transmitter circuit
- RX3310A Receiver Module
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- MAX2440/MAX2441/MAX2442 900 MHz Receivers
- LA4510 power amplifier circuit diagram
- LA4497 power amplifier circuit diagram
- LA4185 power amplifier circuit diagram
- AN7173NK power amplifier circuit diagram
- Ringing switch start protection circuit diagram
- Switching power supply output part circuit diagram
- AC 220V to DC 600V switching power supply circuit diagram
- Small (2~3 meters) neon light electronic transformer circuit diagram
- Constant voltage current limiting charger circuit diagram
