Short pulse relay circuit diagram
Source: InternetPublisher:他们逼我做卧底 Keywords: Circuit diagram relay circuit pulse WIDTH Updated: 2021/01/28
This circuit can transmit the ringing tone of a phone in one room to another room through a voice control circuit. There is no electrical connection between the phones in the two rooms. That is, when the ringing signal is received by the microphone, it is amplified and outputted and then transmitted to another headset.
This circuit can also be used in other situations. For example, if you want to control other processes through a relay, you can connect a circuit shown by the dotted line in the figure to the collector of transistor T3.
Main technical data of the circuit: Working voltage: 6 (3.5~9) V Working current (at 6V): 130uA/480mA Input signal action voltage: 8mV Limit frequency (3dB): 11kHz
- The meaning and importance of circuit protection, common types of circuit protection
- A simple door handle touch alarm circuit
- An automated model railroad layout project using a microcontroller
- Introduction to the internal structure of the Delta winding motor
- Manual automatic air compressor control circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Using P110C to control 6 DC motors simultaneously
- Add one more component to improve the phase failure protection function
- Design and production of radio remote control fan stepless speed regulator
- PIC microcontroller controlled remote anti-theft alarm circuit
- AN7171NK power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Small (2~3 meters) neon light electronic transformer circuit diagram
- EW-8W electronic ballast circuit diagram
- AC voltmeter circuit composed of milliammeter
- CDll4CP logic block circuit diagram
- Field output circuit: TDA3654 circuit diagram
- Transistor light meter circuit diagram
- LT3755 driver LED application circuit diagram
- Simple signal generator for signal tracing
