555 automobile device circuit diagram
Source: InternetPublisher:石榴姐 Keywords: circuit diagram device circuit Updated: 2020/04/20
As shown in the figure is the circuit diagram of the 555 car finding device , including the transmitter and receiver. The transmitter uses 555 as the core to form an oscillator with a medium wave frequency. The oscillation frequency should be slightly lower than the carrier frequency 535kHz of broadcast AM. The frequency value is determined by R1, RP1, and C1, that is, f=1.44/(RP1+2R1)C1 , L1 and C2 form an output resonant circuit, perform frequency selection, and then transmit it through the antenna through C3. The receiving circuit consists of an input frequency selection network and a 741 operational amplifier. The amplification factor of the amplifier depends on the ratio of RP2/R2. LED1~LED5 are used to indicate the intensity of the received signal. With the signal and intensity, the luminous tubes will light up sequentially.
ck="window.open(this.src)" alt="Click to see larger image"/>
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Analysis of the working principle of CMOS/CCD image sensor
- What are the classifications of filters?
- What are the parts of the fpga design process
- What is power factor and three ways to improve it
- Working principle/advantages/disadvantages/size of optical fiber
- Experimental circuit based on 4040 binary adder counter
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Common voltage comparator circuit diagram
- Ceiling fan circuit diagram that can automatically start according to room temperature
- A frequency meter circuit diagram composed of CD4046
- Circuit diagram of verbal rescue box for patients who have fainted
- Radio receiving circuit diagram of TA31136
- Measurement circuit diagram of differential pressure sensing bridge
- Monostable circuit diagram
- Car battery charging circuit diagram
- MM36SB020 two-wire wiring circuit diagram
- 3v to 5v circuit diagram
