Monostable circuit diagram
Source: InternetPublisher:zht24 Keywords: monostable circuit circuit diagram transistor Updated: 2020/04/12
In steady state the left transistor is on and the right transistor is off. Inputting a negative pulse turns the left transistor off and the right transistor on. After a certain period of time, it returns to its original state. This period of time, the quasi-stable time, depends on the size of the capacitor C and the charge and discharge resistor R, which is tm≈0.7RC. For example, C=250uF and the discharge resistor R=18k ohms, then tm=3.15s.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Schematic diagram of car cigarette lighter to USB power port
- 220V Remote Load Monitor
- Using Lead-acid Battery as Power Source for Walkman
- Step-down power supply for driving relays
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- Power supply circuit that can reduce LM317 ripple
- LM317 regulated power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- transistor audio mixer
- SIPMOS transistor control circuit diagram using photoelectric isolation
- superheterodyne radio circuit
- Blocking monitoring circuit
- Variable frequency transistor oscillation circuit
- Pulse trigger monostable circuit
- Monostable circuit diagram using video amplifier and comparator
- 555 voltage controlled monostable circuit
- 555 monostable circuit
- Monostable circuit with clamp
