555 various signal generator circuit diagrams
Source: InternetPublisher:奥特man123 Keywords: signal generator generator circuit circuit diagram Updated: 2020/04/09
This circuit is the timing and audio circuit part of a certain monitoring device model machine. Including 15-20 second periodic pulse wave, second signal and 800Hz audio circuit.
IC 1, R18, R19, and C12 form an astable multivibrator. The oscillation period is T=0.693 (R18+2R19) C12. As needed, R19 can be changed to change the period and duty cycle.
IC2 and R23, R24, C13 form a second clock oscillator; IC 3 is an 800Hz audio oscillator, and its control terminal pin 5 is controlled by the on or off state of VT1, which can emit a pitch-changing sound.
ck="window.open(this.src)" alt="Click to see larger image"/>
- The unidirectional conduction current of the diode, the diode and its common uses
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- In-depth analysis of energy losses in oscillation frequencies
- How to identify common mode interference? Methods to eliminate common mode interference
- Principle set of zero-crossing detection circuit advantages and disadvantages
- This article will tell you the hard requirements of operational amplifiers
- What is a D flip-flop and how does it work?
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- Experimental circuit based on 4040 binary adder counter
- 60Hz time base generator circuit diagram composed of MM5369
- High and low frequency signal generator circuit
- Quantitative pulse generator circuit
- Voltage controlled sinusoidal oscillation signal generator circuit
- Triangular wave signal generator circuit composed of LM359
- Pulse, triangle wave and sawtooth wave signal generator circuit using 566 04
- 20Hz signal generator circuit
- Complementary ramp signal generator circuit diagram
- Second signal generator homemade LED digital clock
- Various analog sound signal generators
