Bidirectional thyristor dimming circuit diagram
Source: InternetPublisher:太白金星 Keywords: Triac circuit diagram dimming circuit Updated: 2020/01/04
This circuit is used to dim the brightness of lamps below 200W, and the output voltage is continuously and steplessly adjusted from 8 to 218V. Replacement of thyristors and bidirectional trigger tubes with larger rated current values can be used with lighting lamps with higher power (such as 1kW ~ 2kW).
ck="window.open(this.src)" alt="Click to see larger image" />
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to choose the right level of integration to meet motor design requirements?
- Servo motor pin diagram/working principle/application
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to remotely control devices using ESP8266 and LPC2148
- How to make a wheeled self-balancing robot using ultrasonic sensors
- An automated model railroad layout project using a microcontroller
- Working principle of one Xipu STR soft starter controlling two motors
- Add one more component to improve the phase failure protection function
- Temperature control circuit design and analysis
- 13 examples of electric drag control circuit diagram
- Pyroelectric automatic door control circuit
- Multi-channel patrol detection control circuit b
- Mobile phone camera flash control circuit
- Table printing machine control circuit
- Three-phase stepper motor control circuit
- High-rise residential walkway lighting control circuit
- Thyristor AC switch circuit 2a
- The simplest bidirectional thyristor dimming light circuit
- Bidirectional thyristor AC stabilized power supply circuit
