Triac circuit diagram with flip-flop TcA 780
Source: InternetPublisher:柯南道尔 Keywords: Triac thyristor circuit circuit diagram flip-flop Updated: 2021/09/14
as the picture shows. The integrated flip-flop in the circuit in Figure a can output a double half-cycle +50mA forward current to control a bidirectional thyristor with a rated voltage of 700V .
Figure b shows a circuit that outputs reverse control current. The +15V power supply charges the 0.22uF capacitor through the 10k ohm resistor. The charging polarity is as shown in the figure, and the transistor BC238 is cut off. When the pulse generated by the integrated trigger is added to the base of the transistor through the two diodes, the transistor is turned on, and the upper end of the capacitor is grounded through the transistor, thus generating a reverse trigger current on the gate of the thyristor, causing it to turn on.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- Build a glove-controlled robotic arm
- Working principle of one Xipu STR soft starter controlling two motors
- Design and manufacture of three-phase motor protection circuit
- An experimental model of an infrared radio alarm
- Magnetic door and window anti-theft alarm
- Motorcycle anti-theft device circuit design
- A novel and practical power line anti-theft and cutting alarm circuit
- 13 examples of electric drag control circuit diagram
- Multi-channel patrol detection control circuit c
- Switching regulated power supply circuit
- Electric contact pressure gauge liquid level automatic control circuit 5
- Bidirectional thyristor AC stabilized power supply circuit
- Bidirectional thyristor AC voltage regulation circuit 03
- Automatic night lighting circuit using bidirectional thyristor
- Gas and smoke alarm circuit using bidirectional thyristor
- Light-controlled street light circuit composed of bidirectional thyristors
- Triac controlled single-phase inductive load circuit
