Single-phase lighting dual-channel mutual power supply circuit diagram
Source: InternetPublisher:子丑寅卯 Keywords: power supply circuit circuit diagram switch Updated: 2020/07/04
As shown in the figure, it is a single-phase lighting dual-channel automatic switching power supply line. When the No. 1 power supply fails for no reason, the backup power supply can be automatically switched on. In the figure, 1K and 2K are small switches , and 1C and 2C are AC contactors. When working, first close the switch 1K, the AC contactor 1C is closed, and the power supply is powered by No. 1 power supply. Then close switch 2K, because 1 and 2C are interlocked, at this time, 2C will not pull in, and power supply 2 is in standby state. If power supply No. 1 is cut off for some reason, AC contactor 1C is released, its normally closed contact is closed, the coil circuit 2C is connected, 2C is closed, and power supply No. 2 is put into power supply. You can also close switch 2K first and then switch 1K to make power supply No. 1 a backup power supply.
ck="window.open(this.src)" alt="Click to see larger image" />
- One-digit display
- Experiment on realizing photoelectric alarm using photosensitive devices
- A white light LED power outage emergency light
- IRS2530D electronic ballast circuit diagram
- Blinking LED circuit diagram based on LDR and resistor
- Design and production of rain control and light control timing controller based on P87LPC764
- Design and production of digital number answering machine
- Three-way music lantern circuit
- Remote anti-theft alarm
- Frost alarm circuit
- Contact switch or proximity sensor circuit
- Voice recording and playback circuit
- Improve lighting power factor circuit
- One light one switch lighting circuit
- Dual power supply circuit
- Rice cooker power supply circuit
- Sony laptop memory power supply circuit (SC486)
- Network card power supply circuit using SC1470 control chip
- Flash camera 6-channel power supply circuit (MAX1566-1567)
- Voltage stabilizing circuit for CPU power supply circuit
