One-way silicon controlled voltage regulator circuit diagram
Source: InternetPublisher:闪电杰克 Keywords: SCR circuit diagram voltage regulating circuit Updated: 2020/04/23
The silicon controlled AC voltage regulator consists of two parts: a controlled rectifier circuit and a trigger circuit. The circuit schematic diagram is shown in the figure below. It can be seen from the figure that the diodes D1-D4 form a bridge rectifier circuit, and the double-base diode T1 forms a relaxation oscillator as a synchronous trigger circuit for the silicon controlled thyristor. When the voltage regulator is connected to the mains, the 220V alternating current is rectified by the diodes D1-D4 through the load resistor RL, forming a pulsating DC voltage at the A and K ends of the thyristor SCR. This voltage is stepped down by the resistor R1 and serves as a trigger circuit. DC power supply. During the positive half cycle of the alternating current, the rectified voltage charges the capacitor C through R4 and W1. When the charging voltage Uc reaches the peak voltage Up of the T1 tube, the T1 tube changes from off to on, so the capacitor C is rapidly discharged through the e and b1 junctions of the T1 tube and R2, resulting in a sharp pulse on R2. This pulse is sent to the control electrode of the thyristor SCR as a control signal to turn on the thyristor. The tube voltage drop after the thyristor is turned on is very low, generally less than 1V, so the relaxation oscillator stops working. When the alternating current passes through the zero point, the thyristor switches off automatically. When the alternating current is in the negative half cycle, the capacitor C is recharged...and so on, the power on the load RL can be adjusted.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to choose the right level of integration to meet motor design requirements?
- Use your smartphone to turn on/off the power in your home
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Infrared blocking alarm device
- Guanghua brand anti-theft doorbell electronic lock circuit
- Homemade short circuit alarm device
- Water supply reminder after water outage
- Capacitor step-down LED drive circuit diagram using thyristor
- Differential amplifier emitter negative feedback gain control circuit
- Multi-channel patrol detection control circuit c
- Flashing wall light control circuit
- Zero-crossing trigger circuit diagram based on thyristor
- A new type of dimming SM9043 integrated circuit
- Simple time delay circuit using two thyristors
- Simple thyristor temperature automatic control circuit diagram
- SCR automatic charger circuit
- Touch type thyristor zero-crossing switch circuit diagram
