Single tube constant current charger circuit diagram
Source: InternetPublisher:偷熊计划 Keywords: Charger circuit diagram single tube constant current WIDTH Updated: 2020/06/03
As shown in the picture is a practical single-tube constant current charger, in which the transistor VT1 plays the role of constant current, and its constant current value is determined by the voltage of the voltage regulator tube and R2. Generally, the voltage regulator tube is selected to be around 3.3V, and the resistor R2 is (30~60 ohms)/(1W~2W). At this time, the charging current is about 50mA~80mA. R3 (200~500 ohms) and LED form a charging indication circuit. As long as the rechargeable battery is connected as shown in the figure, the LED will light up. If the LED does not light up, it means the battery contact is poor. This circuit can charge 1 to 4 AA nickel-cadmium batteries, and the charging time is 12 to 14 hours. Transistor VT1 can be used with 3DD15 or DS11 (plastic-sealed) power tubes. During installation, a radiator should be added to the VT1 tube.
Both chargers do not have a charging control circuit, so the charging time should be mastered when using them to ensure safe charging.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Using Lead-acid Battery as Power Source for Walkman
- Step-down power supply for driving relays
- Recommended circuits for different power on times of LM4911
- The constant current source composed of two transistors can drive high power
- LED Driver ZD1680
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Battery powered switching circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- LA4510 power amplifier circuit diagram
- HA1384 power amplifier circuit diagram
- Nickel-cadmium battery charger circuit diagram
- Video switching circuit diagram
- Electric bicycle Jiateng charger circuit diagram
- MAX1870A - Typical Operating Circuit
- Comparison circuit diagram of LM324
- The ever-changing sound and light analog controller circuit 02
- NCP1014/1028 driver LED circuit diagram
- Sawtooth wave generation circuit diagram with arbitrarily set slope and amplitude
