HA17385 switching power supply integrated controller internal equivalent circuit diagram
Source: InternetPublisher:张三叔 Keywords: Switching power supply equivalent circuit diagram integrated controller WIDTH Updated: 2020/01/30
The HA17385 switching power supply integrated controller adopts an 8-pin DIP package. The picture shows the internal equivalent circuit block diagram. It can be seen from the equivalent circuit block diagram that the HA17385 chip has a 5V reference voltage regulator, oscillator (triangular wave generator), error amplifier and power MOSFET drive circuit, etc. All circuits required to form a switching power supply. The maximum duty cycle of the PWM wave is set by the resistor and capacitor connected to the RT and T terminals of the oscillator.
ck="window.open(this.src)" alt="Click to see larger image" />
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Fabrication of multi-cell lithium battery charging circuit
- Driving circuit of switching power supply field effect tube
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LNK304 non-isolated LED light string driver circuit
- A novel and practical DC low voltage stabilized power supply
- Integrated regulated power supply with continuously adjustable output voltage
- Car Audio Power Supply
- Practical constant current charger-----Constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- LA4555 power amplifier circuit diagram
- LA4510 power amplifier circuit diagram
- Principle circuit diagram of three basic working modes of non-isolated switching power supply
- Constant voltage current limiting charger circuit
- Field output circuit: TDA3654 circuit diagram
- 50W white LED headlight driver circuit diagram based on LT3755
- Signal generator circuit diagram
- Simple signal generator for signal tracing
- Gain adjustable test equipment isolation amplifier circuit diagram
- Guitar noise circuit diagram
