Precision tone generator for instrument tuning
Source: InternetPublisher:司马缸砸光 Keywords: Generators power supplies other power circuits audio Updated: 2020/02/07
Part of this precision audio generator uses an electret microphone to receive the piano's audio signal, which is processed and placed on one line of a dual-trace oscilloscope. Another part of the circuit is used to generate the variable frequency of a digital frequency counter. After adjustment, the audio signal is sent to another line of the oscilloscope and output to stereo headphones.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- ISO113 circuit that can reduce power consumption
- Basic connection circuit of signal and power supply composed of ISOll3
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED Driver ZD1680
- Current/voltage conversion circuit using current converter
- Constant current charger using light emitting diode as voltage regulator
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- Vishay FRED Pt® ultra-fast recovery rectifier launched on the market
- Low quiescent current is an extended battery system
- Determining the prerequisites for successful circuit board design
- Inventory of radio frequency interference rectification error circuits in amplifiers
- Design of data transmission interface circuit for a car driving recorder
- EMC design component selection and circuit design are critical
- Humidity detection circuit schematic diagram
- FET op amp microphone mixer
- Variable reset level ramp generator
- FSK generator A
