Discrete component amplification circuit diagram
Source: InternetPublisher:sigma Keywords: Discrete components amplified circuit diagram WIDTH Updated: 2020/11/03
This circuit amplifies the difference between the given value and the actual value voltage, and the amplification factor can be adjusted. It has a higher voltage regulation coefficient and smaller output resistance. A heat sink is installed on the output transistor 2N3055 with a thermal resistance < 5g rd/W. A heat sink must also be installed on the BC140.
ck="window.open(this.src)" alt="Click to see larger image" />
- Homemade high quality preamplifier tone circuit
- The easy production of several top-quality tube preamplifiers
- Make a pocket amplifier with 8550 and 8050
- DIY a stylish Bluetooth speaker
- Minimum output noise/reduced output power circuit using LM4910
- Stereo phono amplifier circuit with bass control composed of LM1877
- Class AB2 Amplifier-McIntosh MC80
- Auxiliary audio power amplifier circuit using LM4732
- LM4901 audio power amplifier circuit (MSOP package)
- Tube single-ended class A 300B power amplifier circuit
- AN7177 power amplifier circuit diagram
- AN7149N power amplifier circuit diagram
- Subwoofer crossover amplifier circuit diagram
- 8W audio amplifier integrated circuit
- AC 220V to DC 600V switching power supply circuit diagram
- EW-8W electronic ballast circuit diagram
- MK5087+TWH630 remote control transmitter circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Spike peak measurement circuit diagram
- Square wave clock circuit diagram
