Simple 12V to 6V converter circuit
Source: InternetPublisher:containsmachine Keywords: Comprehensive power supply Updated: 2021/04/13
![Simple 12V to 6V converter circuit](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/293fefffb78a2ef806ba16605721e31c.png)
You're out and about and you forgot to bring a DC-DC converter in your car, but you need it. This simple DC to DC converter circuit can help you.
This DC-DC converter circuit enables transistor-based items such as radios, audio tapes, and other electrical equipment to operate from a car's power supply. The table below gives the different voltage values of resistors and specified diode types. Multiple voltage switching arrangements can be incorporated if required. For high currents, the transistor should be mounted on a heat sink.
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- Boost drive circuit composed of RT8450
- Integrated regulated power supply with continuously adjustable output voltage
- Car Audio Power Supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- DC 12V to AC 100V inverter power supply circuit design
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Recording level power supply circuit
- Household emergency power circuit
- Antenna amplifier synchronous power supply circuit
- ±15V active servo power circuit
- Common power circuits and applications 01
- DC-DC conversion power supply circuit
- CTX-C2 dual-band high-resolution color display power circuit
