Using transistor DC/DC converter circuit diagram
Source: InternetPublisher:无人共我 Keywords: Converter circuit diagram transistor DC/DC converter output voltage Updated: 2021/10/21
The figure below is a low-power DC/DC converter circuit composed of transistors . Among them, Figure (a) is a circuit that converts a +5V input voltage into a -12V output voltage , and Figure (b) is a circuit that converts a +5V input voltage into a +12V output voltage. For any circuit, if the output voltage exceeds the stable voltage of the voltage regulator tube VDw, negative feedback is applied to the drive transistor VT1 to keep the output voltage constant. Therefore, the output voltage is equal to the stable voltage of the voltage regulator tube. If the stable voltage is changed, the output voltage can be adjusted.
When the circuit does not vibrate, just change the value of capacitor C1. The output current is 15~20mA, the voltage stability is about 5%, and the efficiency is 80%~90%.
ck="window.open(this.src)" alt="Click to see larger image" />
- The basic principles of power supply design. What are the key components of a power supply?
- How about the boost converter TPS61299?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Using Lead-acid Battery as Power Source for Walkman
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Parallel DC regulated power supply circuit diagram
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- USB power socket using the car battery
- MAX1811 Lithium Battery Charger Production
- Interleaved parallel low-voltage high-current DC/DC converter schematic diagram
- DC-DC converter circuit diagram connected to PFC circuit
- Step-down DC-DC converter circuit diagram (b)
- MC33466 series buck converter circuit diagram
- Step-down DC, DC converter circuit diagram
- Step-down DC and DC converter circuit diagram using HS7076
- Boost converter circuit diagram using MAX644
- High input voltage DC, DC converter circuit diagram
- DC and DC converter circuit diagram using thyristor b
- DC and DC converter circuit diagram using thyristor a
