Bandpass filter circuit composed of single power supply op amp 8FC7
Source: InternetPublisher:酷到被通缉 Keywords: Single power supply bandpass filter filter circuit op amp Updated: 2020/08/16
The figure shows a single-supply low-voltage band-pass filter circuit. This circuit uses a single power supply operational amplifier 8FC7 to form a second-order band-pass filter , and the power supply voltage range can be from 3V to 30V. When determining the values of each component, first determine the center frequency f0 of the bandpass filter , and then select the appropriate capacitor C (C=C1=C2) according to the table below. Then select the Q value. The Q value is a parameter that represents frequency selection characteristics. The higher the Q value, the narrower the passband. When Q=10, a frequency response characteristic of -40dB per octave can be obtained. But the Q value is too large and the circuit stability is poor. Generally, the Q value is chosen to be less than 10. The closed-loop gain K should ensure that the output amplitude is as large as possible without distortion. Generally KF is less than l. Finally, R1, R2, and R3 are calculated from the following three formulas.
- Sharing layout and tips for multi-rail power supply design
- Introduction and principle analysis of switching regulated power supply
- Energy-saving motorcycle rectifier regulator
- Visible laser digital control modulation driver
- Transformerless AC-DC constant current LED driver circuit
- How to use SBR to improve power conversion efficiency
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- A novel and practical DC low voltage stabilized power supply
- MAX1811 Lithium Battery Charger Production
- Application circuit when using single power supply
- TDA2030 application circuit-dual power supply operation
- LM3875 practical circuit-single power supply
- Typical bandpass filter circuit
- High Q value bandpass filter circuit diagram
- Multiple feedback bandpass filter
- Multiple feedback bandpass filter circuit
- Single Supply Bridge Sensor Transmitter Circuit
- AMP04 type precision single power supply instrument amplifier circuit
- 750HZ sixth-order bandpass filter circuit diagram
