Comes with lead-acid battery rechargeable LED emergency light circuit diagram
Source: InternetPublisher:李商隐身 Keywords: Emergency lights circuit diagram lead-acid battery LED Updated: 2021/08/21
The working principle diagram of the circuit drawn based on the actual object is shown in Figure 5. The 220V AC mains power is stepped down by the capacitor and rectified by the diode to charge the lead-acid battery , and the red LED is used as a charging indicator. After charging, when using the button switch K, close the button switch K, which will first turn on the three colorful flashing LEDs, emitting a dreamy and unpredictable colorful light, adding some fun to life at night. Press the switch K again to turn off the colorful flashing LEDs, and then Pressing it again will turn on 24 high-brightness LEDs connected in parallel. Due to the large number, the lighting effect is very good.
When the lead-acid battery voltage is 4V, the measured operating current of the colored lights is about 60mA, and the high-brightness LED current reaches more than 600mA. Such a large current not only prevents the lighting time from being too long after each full charge, but also causes damage to the internal structure of the battery and shortens its service life. Therefore, a small-value current-limiting resistor must be connected in series to the high-brightness LED. When the test selected 1.2Ω, the operating current finally dropped to 320mA, and the brightness change was not obvious. Since the lamp has not been changed much, the modified circuit schematic is omitted.
Through the above analysis, it is found that most of the various LED light circuits sold on the market are too simple. Although the price is very cheap, it will still cause a waste of energy objectively. Only through some reasonable improvements can it not only retain its economical and portable advantages, but also Effectively improve safety and reliability of use.
- Build a Bluetooth-controlled wireless scoreboard
- battery charging circuit
- Practical sensitive light-controlled switch circuit diagram
- 4-digit incandescent lamp display circuit
- Motor speed photoelectric control circuit
- Desk lamp dimming soft switch circuit
- Mains undervoltage and overvoltage protection circuit 2
- Remote anti-theft alarm
- Touch/wireless remote control dimmer light circuit diagram
- Small current anti-theft alarm circuit
- MAX684 charge pump driving white LED circuit diagram
- SG1524 driver LED circuit
- LED driver circuit diagram powered by solar cells
- "clairvoyance" charger circuit diagram
- Three-color marquee circuit diagram
- Level display circuit diagram composed of LED level meter driver integrated circuit
- Inpatient pager circuit
- Machine-made tile humidity measurement circuit
- Light controlled night light lighting circuit
- Medicine bottle assembly line counting circuit
