Level display circuit diagram composed of LED level meter driver integrated circuit
Source: InternetPublisher:toothache Keywords: LED circuit diagram integrated circuit Updated: 2020/10/28
The 10-point LED level display circuit composed of two BA6104 five-digit LED level meter driver integrated circuits is shown in the figure.
The 10-point LED level display circuit composed of two BA6104s is shown in the figure. Adjust the Vref of the 7th pin of IC1 to make the 5 LEDs L1~L5 in IC1 all bright; adjust the Vref of the 7th pin of IC2 to make the L1~L5 of IC2 All 5 LEDs of L5 are on. The lighting voltage is twice that of IC1. The lighting sequence is from L1 to L5 of IC1 to L1 to L5 of IC2.
- One-digit display
- Lighting lamp voltage stabilizing circuit (2)
- One of the bead-type emergency light circuits
- Lighting sound-activated switch circuit using thyristors Part 3
- Desk lamp dimming soft switch circuit
- Electronic music dimming desk lamp circuit
- WT8089 holiday lights ASIC
- Fluorescent lamp electronic ballast circuit 11
- Photoelectric adjustment circuit
- Touch/wireless remote control dimmer light circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- MAX8630Y/ MAX8630Z driving white LED circuit diagram
- Circuit using NCP1216 to drive LED
- Ambulance electronic flash signal circuit diagram
- High battery life LED circuit based on GEC8310
- Positive terminal buck/boost LED constant current drive circuit diagram
- Five-digit LED level indication driver integrated circuit typical circuit
- Power outage sound and light alarm circuit
- Digital camera flash control circuit
- Medicine bottle assembly line counting circuit
