LED display control circuit diagram in the counter
Source: InternetPublisher:柯南道尔 Keywords: LED display control circuit diagram display control counter Updated: 2021/07/12
As shown in the figure, the decimal seven-segment storage-decoding-drive unit 74143 is used in figure a. This unit has constant current output for all segments. When the voltage is 5V, the current of each segment is about 15~22mA. The BCD data of the seven-segment decoder can be taken out from pins 17 to 20. Pin 22 is used for carry, that is, when the count value reaches 9, it is low level, and the rest is high level. This signal can be used to control the previous counter .
Figure b is used to control a 1-digit or 1 and 1/2-digit seven-segment LED display circuit. SAB3211 is used for 4-bit binary counting. A binary counter (FZJ151) or a decimal counter (FZJ141) can be connected as needed . The power supply voltage is 9~16V.
- Laser detection and indicating device system circuit design
- Musical doorbell without buttons
- battery charging circuit
- One of the water full alarm circuits
- Infrared remote control dimmer light circuit
- AC and DC dual-purpose flash light
- Microwave Doppler warning circuit
- Economical and practical delay light circuit
- Temperature control alarm circuit
- Photoelectric adjustment circuit
- Corridor light control circuit diagram
- Capacitive sensitive flash control circuit diagram
- Using TC9153 electronic volume control circuit diagram
- Color changing LED display circuit
- Control circuit diagram of two-speed motor
- Manual forward control circuit diagram
- Interlocking control circuit diagram of two electric motors
- Forward rotation control circuit diagram with self-locking
- Multi-point motor control circuit diagram
- Bus door light automatic control circuit diagram
