MAX6969 chip 16-port 5.5V constant current LED driver circuit diagram
Source: InternetPublisher:傻阿乐 Keywords: Constant current LED drive circuit Updated: 2020/04/08
The MAX6969 is a serial-interface LED driver that provides 16 open-drain, constant-current-sink, 5.5V-rated LED driver outputs. The MAX6969 operates from 3V to 5.5V supplies. The MAX6969 and LED power supplies can be powered up in any order. All constant current outputs are set with an external resistor up to 55mA each. The MAX6969 is controlled using a 25Mb, industry-standard 4-wire serial interface.
The MAX6969 uses an industry-standard shift register plus latch serial interface. Data is shifted into the 16-bit shift register through data input DIN and clock input CLK. After 16 clock cycles, the input data appears on the output DOUT, allowing multiple MAX6969s to be cascaded. The latch enable input LE loads the 16-bit data of the shift register into the 16-bit output latch to set the switching state of each LED. Output enable/OE controls the switching status of all 16 outputs, and its fast response characteristics are suitable as a PWM input for controlling LED brightness.
For applications requiring LED failure detection, consider the MAX6984*, which automatically detects open LEDs.
For safety-related applications that require a watchdog timer, consider the MAX6979, which has a fail-safe feature that turns off the output if the serial interface stops operating for more than 1 second.
The "shift register + latch" type LED driver family to which the MAX6969 belongs contains a total of 12 members. These include 8 -port and 16-port types, with 5.5V or 36V rated LED output, and some models have LED open circuit detection and watchdog functions. All models operate from 3V to 5.5V supplies and are guaranteed to perform over the -40°C to +125°C operating temperature range.
Key Features
25Mb industry standard, 4-wire, 5V serial interface
3V to 5.5V logic power supply
16 constant current LED drivers with output voltage rated to 5.5V
Outputs up to 55mA continuous current per channel
Setting the output current with a single resistor
3% current matching between outputs
6% current matching between ICs
High thermal capability 24-pin package
-40°C to +125°C temperature range
Certified by Underwriters Laboratories (UL)
Application/Use
architectural lighting
Game features
Marquee display
process sign
traffic light
information board
This product is derived from a 12-shift register latch LED driver family that offers 8-port/16-port, rated 5.5V and 36V outputs, with/without LED fault detection and watchdog timer.
Typical working circuit
- Making a photometer with light measuring function
- USB powered portable light
- Six LED stereo VU display circuit built with IC LM3915
- "OR" logic element configuration circuit
- Corridor automatic light-off device
- One of the bead-type emergency light circuits
- Gift lamp music box circuit
- Economical and practical delay light circuit
- Two-way electronic music doorbell circuit
- Electronic rapid starter for fluorescent lamps
- Switching power supply constant current charger circuit diagram
- Lithium battery constant current and constant voltage charging circuit diagram
- 5A constant voltage/constant current regulated power supply
- Constant current charging circuit
- Constant current amplifier circuit
- Dynamic constant current load for testing fuel cell batteries
- Constant current recovery type voltage-frequency converter circuit diagram
- Fully automatic two-stage constant current charger
- Multipurpose constant current charger
