Use PC serial port to read 16 digital input channel circuit diagram
Source: InternetPublisher:萌面大虾 Keywords: Circuit diagram PC serial port WIDTH Updated: 2020/12/28
The RS-232 serial port has 4 input lines (pins 1, 6, 8, 9) that are accepted by two dual 4-input multiplexers ( IC 1 and IC2) for 16 channels of input, and two output lines (pins 4, 7 ) controls the input channel selection. Each line allows the PC to read 4 input channels under the control of the C program. Pin 4 powers the IC through VD and charges C1. When pin 4 is low, C1 keeps supplying power to the IC . VDW1 and VDW2 limit the output voltage to -0.6~+5.1V.
ck="window.open(this.src)" alt="Click to see larger image" />
- Signal diode arrays/configurations, freewheeling diode operation
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What are the classifications of filters?
- Datasheet/Pinout/Technical Specifications of LMC555
- Working principle/advantages/disadvantages/size of optical fiber
- How does RCCB work?
- Structural diagram and function of sliding resistor
- What is a Demultiplexer
- Summary of knowledge points of multiplexer
- Hardware circuit diagram of ultrasonic range finder
- AN7147 power amplifier circuit diagram
- 75 watt audio amplifier circuit diagram with load line protection
- Video switching circuit diagram
- CDll4CP logic block circuit diagram
- 5V-USB charger circuit diagram
- Field output circuit: TDA3654 circuit diagram
- Comparison circuit diagram of LM324
- Hall switch collector output interface circuit diagram
- Circuit diagram for driving 4 white LEDs based on charge pump
