Can type FM radio circuit diagram
Source: InternetPublisher:fish001 Keywords: Radio circuit machine circuit diagram FM radio Updated: 2021/08/05
The radio not only has good listening effect, but can also be used as a decoration around the neck. The machine is powered by two AA batteries. When the voltage is as low as 1.8V, the radio effect is still very good. In the figure, L1 and C5 are used to select the radio station. The high-frequency signal is sent into the circuit (pin 12) by the earphone lead that also serves as the antenna. The audio signal output from pin 14 is amplified by V1 and V2 for low frequency and then drives the earphone. L1 uses 0.6mm enameled wire to wind 6 turns around the frame of 3, and then takes off the frame to make a bodiless coil. C1 uses a small single-connected variable capacitor, and the rest use small ceramic capacitors. V1 and V2 use imported pipe K9014.
ck="window.open(this.src)" alt="Click to see a larger image" />
- How to use CAN protocol in Arduino
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- TA7792 Medium Wave Radio Circuit Diagram
- Convenient and practical electric guitar wireless transmitter
- Production of a FM wireless microphone
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- nRF902 FSK 868 MHz Transmitter
- RXM-433/418/315-LC-S Series Receiver Modules
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Hearing aid, hypnosis, memory enhancement multi-purpose machine circuit diagram
- Transmitter circuit diagram
- JFET-MOSFET headphone circuit diagram
- Secondary frequency conversion SSB/CW receiver circuit diagram
- Can type FM radio circuit diagram
- Lam Soon AYE-203B multifunctional food processor circuit diagram
- Little Swan Fangtai type range hood circuit diagram
- Wanbao YP5-5AZ automatic range hood circuit diagram
- Chiba YP5-5B double-head range hood circuit diagram
- Clever use of KD-28 as a single-chip radio circuit diagram
