Ceramic filter radio amplifier circuit diagram
Source: InternetPublisher:zht24 Keywords: radio circuit diagram ceramic filter Updated: 2020/08/05
The figure shows the application of two-terminal and three-terminal ceramic filters in the amplifier circuit of AM semiconductor radio . Ceramic filters B1 and B2 are used for 465kHz IF bypass, and B1 is used for IF coupling. B1 uses a narrow-band filter, which is connected in parallel to the emitter resistor of VT1 to help eliminate interference and noise. MA is a wide-band filter, which is beneficial to improving the sound quality of the radio.
- Methods to reduce mutual coupling between antenna elements
- TA7792 Medium Wave Radio Circuit Diagram
- Change the frequency of the campus radio
- Wireless doorbell production
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- Common RF receiving circuit design for toys (3 high-frequency parts)
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- CYWUSB6932 GFSK 2.4 GHz Wireless USB Interface Transmitter
- Circuit diagram of a voltage doubler rectifier electronic ballast
- Wireless microphone circuit diagram composed of 9018 triode
- Intermediate frequency amplifier circuit with neutralization circuit commonly used in radios
- Remote control detector circuit diagram
- Double tuned IF amplifier circuit for radio
- Typical radio single-tube frequency conversion circuit
- 20W bus radio and amplifier circuit
- Micro AM/FM Stereo Radio
- radio timing circuit
- Low frequency amplifier circuit diagram for car radio
