MLX10803 application circuit
Source: InternetPublisher:明天见 Keywords: Application circuit switching frequency WIDTH Updated: 2021/05/21
The MLX10803 is a highly adaptable LED driver. Compared to existing solutions, it contains several reference inputs and is designed to perform temperature compensation on external sensors . This ensures that the LED light is continuously maintained when the temperature changes. The output is stable. The MLX10803 offers superior performance in terms of temperature compensation and intelligence9 such as dimming down the brightness and a soft increase in brightness at startup. Typical efficiencies vary from 70% for single LED applications to over 95% for LED array applications. MLX10803 is suitable for applications with unloading voltages up to 80V, and its operating temperature range is -40~125℃.
MLX10803 uses a pseudo-random switching frequency generator to reduce electrical noise. The inductor L1 should be determined based on the switching frequency and LED current. In the circuit, the switching frequency should be lower than 150kHz. If the LED current is between 0.5~1A, L1 and L2 are 100uH.
- Example of LED AC drive circuit
- LED acceleration and deceleration motion display composed of CD4017
- Infrared detection alarm
- Simple electronic doorbell circuit
- Motor speed photoelectric control circuit
- Simple light-controlled street light circuit (7)
- Application circuit of CAT3606
- Remote anti-theft alarm
- SH-803R holiday lights ASIC
- Bedside lamp controller circuit
- LA4555 power amplifier circuit diagram
- LA4497 power amplifier circuit diagram
- Principle circuit diagram of three basic working modes of non-isolated switching power supply
- Automatic disconnect battery charger circuit diagram
- Constant voltage current limiting charger circuit diagram
- Fuse/thin wire transmitter circuit diagram
- Field output circuit: TA8403 circuit diagram
- MAX16834 driver LED circuit diagram
- Sawtooth wave generation circuit diagram with arbitrarily set slope and amplitude
- Signal generator circuit diagram
