Field output circuit: TA8403 circuit diagram
Source: InternetPublisher:明天见 Keywords: Circuit diagram output circuit MDASH WIDTH Updated: 2021/12/15
TA8403
1 pin: 0V& mdash ;—Ground
Pin 2: 12.4V - field output
Pin 3: 25V - field output stage power supply
Pin 4: 1.0V——Field excitation signal input
Pin 5: 0.6V - phase compensation
Pin 6: 24V - power supply
Pin 7: 1.5V—& mdash ;Pump power output end
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What are the classifications of filters?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Important things to know about PCB routing and how to design the right routing for your PCB
- Share a Motorola amplifier circuit
- Structural diagram and function of sliding resistor
- LED Bicycle Lights
- Digital number selection machine
- Mosquito killer lamp circuit
- Dual adjustable power circuit
- Three-phase stepper motor control circuit
- FGDF-3 three-phase low-temperature iron-plated power supply main circuit
- Lightning protection wiring c for direct distribution generators from 300 to 1500kW
- Simple buzzer circuit 1b
- Solar water heater water automatic control circuit diagram
- AN7116 power amplifier circuit diagram
- 8W audio amplifier integrated circuit
- SPT1141/1151 multi-function switch controller circuit diagram
