Circuit using MAX1578 to drive high-power white LED
Source: InternetPublisher:ohahaha Keywords: High power white LED Updated: 2020/12/29
This circuit includes a charge pump regulator ( IC 1) suitable for camera flash applications. This device can provide current regulation function for up to 8 white LEDs . Connecting LED1 to LED8 in parallel can provide a current of up to 480mA for a single 1W LVXEONStar high-power white LED module. When the potential of the open-drain input pin EN is pulled down to ground, IC1 enters shutdown mode. A compact and low-cost thermal shutdown circuit can be constructed using a thermistor and a dual open-drain comparator ( IC 2) with an internal reference. When VTHERM drops below the 1.2V internal reference voltage, internal comparator A pulls the EN pin potential down to ground. This operation is performed when the temperature of the thermistor (R2) is very high. The internal comparator B is used to provide open circuit fail protection, that is, when the thermistor contact is open, the EN pin potential will be pulled low. When an open-circuit fault occurs in the thermistor, VTHERM is pulled high by R1, causing comparator B to pull the EN pin potential low. Resistor dividers R3 and R4 are used to set the threshold voltage for open circuit faults, and resistor R1 and thermistor R2 are used to set the thermal shutdown threshold. When the temperature is too high and the thermistor has an open or short circuit failure, the white LED will be turned off.
- Digital level display (CD40147, CD4511)
- Laser detection and indicating device system circuit design
- Low illumination amplifier circuit
- One of the water full alarm circuits
- SC3071 touch step dimming light circuit
- Simple electronic doorbell circuit
- WT8089 holiday lights ASIC
- Remote anti-theft alarm
- Fluorescent lamp electronic ballast circuit 11
- Photoelectric adjustment circuit
- High power IGBT high frequency inverter welding machine circuit diagram
- Multiple sets of colorful light chain circuits that flash in cycles Part 5
- Pre-frequency crossover power amplifier
- Novel high-power multi-functional amplifier module 04
- TEA-1000 power amplification improvement example 02
- High power DC motor speed regulating circuit
- Use SH-803R to make high-power holiday lights
- Overcurrent protection circuit diagram of high-power DC motor
- High power festival flowing water light chain
- High current, high power amplifier circuit
