High power DC motor speed regulating circuit
Source: InternetPublisher:三岁就很酷 Keywords: High power speed control circuit DC motor speed control autotransformer Updated: 2021/05/17
This article introduces a 600 W DC motor speed regulation circuit. This motor is the take-up motor of a
reel machine. In order to take up the thread reeled out by the reel machine, the
take-up speed often needs to be adjusted. The method is to adjust the voltage with an autotransformer and then rectify it to control
the speed of the DC motor. size. However, autotransformers that are frequently adjusted are easily burned
out, and voltage regulators are often burned out due to broken carbon brushes or poor contact of the carbon brushes. To this end,
this article introduces a single-phase speed control circuit (Figure 2-49), which can replace the original speed control circuit
. After testing, this circuit is very practical. The entire circuit is installed in a box as big as a matchbox
, and the potentiometer is fixed on the control panel.
- Peripheral circuit of automotive motor controller power supply chip
- Tutorial for building a remote-controlled Arduino Air-Boat
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of one Xipu STR soft starter controlling two motors
- One-way rotation circuit of motor controlled by contactor
- Add one more component to improve the phase failure protection function
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Electric vehicle battery charging protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Infrared blocking alarm device
- Flashing wall light control circuit
- Multiple sets of colorful light chain circuits that flash in cycles Part 5
- One of the fade-in and fade-out light switch circuits
- Super fool high power amplifier module 01
- Use SH-803R to make high-power holiday lights
- High-power "flow-type" control lantern circuit
- High power non-contact street light automatic control circuit
- Simple high-power temperature control circuit
- High-power "flowing water" control lanterns
- High power neon light electronic transformer circuit
