Use the TV remote control to turn off the power supply of electrical appliances circuit diagram
Source: InternetPublisher:已注销 Keywords: Power supply circuit diagram TV remote control RC Updated: 2020/04/12
When the infrared receiving tube PH302 receives the signal from the remote control, it outputs a low-frequency signal through the CX20106A frequency selection amplifier. This low-level signal charges C through D and R, causing the voltage at the negative terminal of C to gradually decrease. When the potential of the negative terminal of C drops below 1/3Vcc, the discharge tube of the 555 circuit is cut off, the relay is released due to electric shock, and the power supply is cut off. The RC in the circuit can set the action sensitivity. Generally, press the remote control for 3 to 5 seconds. When the power is turned on, pressing the S1 circuit will cause the relay to self-lock.
- How to use CAN protocol in Arduino
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- Pocket Wireless Microphone
- RX3408 FM/FSK 500~20 MHz Receiver
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- GPS RF front-end circuit composed of MX2740
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- TR5100 FM 150~15 MHz transceiver
- nRF903 GMSK/GFSK 950~430 MHz transceiver
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- Add amplifier before attenuation network
- Low noise ±12V power supply circuit diagram for single-ended 15V input supply
- Timing AC power supply circuit diagram that supplies power for 0-1 hour
- Stabilized current and voltage stabilized transistor amplifier power supply circuit diagram
- 3×8 LED driver circuit with overvoltage protection function
- NCP1200 driver LED circuit
- Partially resonant RCC power supply circuit diagram
- RCC mode switching power supply circuit diagram
- RC phase shift type oscillation encoder
- RC clock circuit diagram
