20w bus radio and amplifier circuit diagram
Source: InternetPublisher:王达业 Keywords: Amplifier radio machine circuit diagram Updated: 2021/07/25
The picture shows a 20w bus radio and amplifier circuit, which is a bus radio and amplifier circuit using TDA2005S dual low-frequency power amplifier integrated circuit. The input terminal in the picture can be connected to the low-frequency voltage amplification output stage of a microphone or radio. Each TDA2005S outputs 10W power and can carry 4 speakers. The two outputs can carry 8 speakers, which can be placed in different locations in the car. The total output power can reach 20W.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- 6P3P parallel 20W power amplifier experiment
- Two unique tube preamplifiers
- Telephone volume amplifier circuit
- 6N5P tube direct-coupled single-ended amplifier
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- Using Shuguang 350C tube to make tube amplifier
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- LMl876 is used to assist the audio power amplifier circuit
- Application of BTL power amplifier circuit composed of LM3886
- Inductive wireless earphone circuit diagram
- Bus amplifier circuit using TDA2005S
- Economical I²C bus controlled stereo decoder TDA9853H
- Double tuned IF amplifier circuit for radio
- Switching battery charger circuit diagram
- High-quality field effect amplifier movement
- 27.145 MHz NBFM receiver circuit diagram
- Matching circuit between record player and amplifier
- Add a timer circuit to the radio
- JFET-MOSFET headphone circuit diagram
