High-quality field effect amplifier movement
Source: InternetPublisher:Lemontree Keywords: Amplifier BSP TIMES mono Updated: 2021/09/30
The amplifier cores introduced in this article all use power amplifier modules with field effect tubes as output, equipped with large-capacity rectifier filter curing
components and 1 2-slot radiators. Its appearance is shown in Figure 3-25, and the overall structure is extremely simple with 6 buttons. Its power size. There are three types of amplifier
cores: 80W, 190W mono and 2×80W dual-channel. The specifications of the three components required for different power combinations
are shown in Table 3-5. The following introduces the internal structure.
(1) High-power field effect power amplifier module.
Figure 3-26 shows the appearance, pins and internal circuit principles of the mono power amplifier module. There are three packaging structures of 80w, 190W and
2×80W according to the output power. They all use a typical differential input fully symmetrical complementary OCL-power amplifier circuit, and the final power amplifier uses
a pair of high-power and high-speed field effect transistors. This module circuit has high input impedance, good mid-point zero potential stability, offset
voltage less than 30mV, gain 30dB, and its frequency band has good flatness characteristics within 10Hz ~ 50kHz.
- Make a Economical and Practical Rectifier Voltmeter
- Homemade refrigerator monitor
- Simple and practical motor short circuit tester
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Simple infrared detector
- Infrared detector
- A circuit for qualitatively testing capacitor leakage
- 4-range digital voltmeter circuit using ADD3701
- A low-cost inductance meter consisting of a single IC
- Electric massager circuit
- Greenhouse temperature control circuit
- Poultry warming temperature control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Diode Balanced Mixer Circuit
- Series crystal oscillator
- OTL low frequency power amplifier circuit
- common emitter amplifier circuit
- color discrimination circuit
- Motorcycle flash light circuit
