Up and down slope control circuit diagram
Source: InternetPublisher:李商隐身 Keywords: Control circuit diagram WIDTH Updated: 2020/08/07
This circuit uses Silico ni x DG387CJ solid circuit relay to generate a switch from an up slope to a down slope, decelerating the servo when it is in the new zero position. The slope depends on the adjustment position of R1 and R2. This circuit arrangement ensures the best servo mechanism system response at low cost. A1 detects that the input signal is not zero, and starts the photoelectric isolator A3, causing A4 to switch. The positive ramp generated by A5 moves the system load toward the desired position, causing the feedback voltage of the servo mechanism to offset the control input voltage. When this voltage drops to within 0.7V from the ground potential, A1 outputs " 0 " and A3 is cut off. A4 starts the down ramp waveform to decelerate the system until it stops. For a slope of 20V/s, take C=0.33uF, R3 =1.8M Europe.
ck="window.open(this.src)" alt="Click to see larger image" />
- A simple magnetic switch circuit sharing
- Servo motor pin diagram/working principle/application
- How to Make a Simple Chicken Incubator
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- DIY an electromagnetic levitation device
- Simple phase failure protection circuit composed of intermediate relay
- Simple three-phase motor phase loss protection circuit
- Audio interface protection circuit
- Infrared detection alarm
- Night dog barking anti-theft reminder circuit
- LA4475 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Differential amplifier circuit diagram schematic diagram
- Nickel-cadmium battery charger circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Comparison circuit diagram of LM324
- PLC circuit diagram of CNC machine tool
- Circuit using NCP1216 to drive LED
- LinkSwitch-PL series LED driver circuit diagram
