Start circuit diagram using relays, etc.
Source: InternetPublisher:闪电杰克 Keywords: Starting circuit circuit diagram relay power supply Updated: 2021/08/16
As shown in the figure below, the figure below is a starting circuit composed of relays , etc. Connect the resistor R to the input end of the power supply. R has two functions. One is to prevent the impact current on the large capacitor C1 from affecting the power supply itself when the power is turned on. The other is to delay the load receiving power for a few seconds. During this process, because the relay J at the output end cannot reach the pull-in voltage of 12, the pull-in R is connected to the circuit to limit the current and reduce the voltage. As the power supply completes charging C1 and C3, the relay J contact pull-in short circuit R, at this time, the power supply enters the normal working state. ck="window.open(this.src)" alt="Click to see larger image" />
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- DIY an electromagnetic levitation device
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and principle analysis of practical electric curtain remote control device
- Audio interface protection circuit
- Homemade short circuit alarm device
- Password type motorcycle anti-theft device
- Frequency sensitive rheostat automatic forward and reverse starting circuit
- Yanbian delta-shaped three-stage step-down starting circuit
- Auto-coupling step-down starting circuit that can be controlled manually and automatically
- LZQ1-10-55 type auto-coupling step-down starter starting circuit
- XJ10 series auto-coupling step-down starter starting circuit
- Resistor-capacitor composite buck start circuit
- Forward rotation starting circuit with self-locking function
- MAX687 automatic startup circuit diagram after power-on
- Motor restart circuit after power outage
- Single board computer automatic reset and start circuit
