Grid disconnection alarm circuit diagram
Source: InternetPublisher:已注销 Keywords: Alarm circuit power grid circuit diagram Updated: 2021/06/27
The circuit working principle of this device is shown in Figure 13. When the wire mesh Fe is intact, the ① and ② pins of LSE are in collusion, and its ④ pin outputs high level, the transistor VT is cut off, the relay J is in the released state, and the alarm does not work. If the barbed wire Fe is cut (any section), the ① and ② pins of LSE are equivalent to open circuits, and its ④ pin changes from the original high level state to the low level state, and the transistor VT is turned on, thus causing the relay to J excitation is closed, its normally open contact j is closed, and the power supply of the alarm circuit is turned on , so the alarm sounds.
ck="window.open(this.src)" alt="Click to see larger image"/>
- Build a Bluetooth-controlled wireless scoreboard
- One-digit display
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of a practical electronic counting device
- Practical sensitive light-controlled switch circuit diagram
- Electronic massage and acupuncture device circuit
- Infrared remote control device circuit
- "OR" logic element configuration circuit
- Desk lamp dimming soft switch circuit
- Simple sensor alarm
- Infrared anti-theft alarm circuit
- Delayed voice anti-theft alarm circuit
- Voice type refrigerator temperature rise alarm circuit
- Parking and incoming call alarm circuit (3)
- Gas alarm circuit
- Multi-channel remote control alarm circuit b
- Telephone line protection alarm circuit
- Door opening alarm circuit diagram
- Road ice alarm circuit diagram
- Proximity alarm circuit diagram using SCR
