Capacitor cleverly used as transformer circuit
Source: InternetPublisher:子丑寅卯 Keywords: Power rectifier unit Updated: 2021/08/10
As shown in the picture, a capacitor is used to replace the commonly used transformer to reduce the 220V mains power to an AC low-voltage circuit required for a rectifier. In the circuit, the voltage is mainly reduced by capacitor C1, with a withstand voltage of 400V; the capacitance of C1 is determined based on the output current. Under the condition of 220V/50Hz, the value of capacitor C1 and the output current are estimated as follows: C=15I where: I is the output current in A; C is in μF. Component selection: C1 can use paper metal film capacitors or paper oil-immersed capacitors, with a withstand voltage of 400V. In order to avoid that there is still charge on C1 when the power is turned off, a 1MΩ bleeder resistor R1 is connected across both ends of C1. Capacitors C2, C3, C4, and C5 are all set up to eliminate modulated hum and other high-frequency interference. C6 is the filter capacitor, RL is the load resistor
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Using Lead-acid Battery as Power Source for Walkman
- Fabrication of multi-cell lithium battery charging circuit
- The constant current source composed of two transistors can drive high power
- LED Driver ZD1680
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- Design of electric vehicle charger
- Mc34063 MP3 Switching Charger
- How to Select Modular EMI Filters for AC-DC Converters
- Rectifier spike absorption circuit
- Stabilized multi-voltage rectifier circuit with adjustable output voltage
- Voltage stabilization control circuit in power circuit
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- One of the transistor stabilized current power supply circuits
- Diamond differential input power amplifier power circuit
- Super Class A power amplifier power circuit
- Common power circuits and applications 02
