Various waveform signal generators
Source: InternetPublisher:太白金星 Keywords: Wireless communication rectangular wave waveform signal generator Updated: 2021/03/08
The circuit is as shown in the attached picture, which is composed of a six-inverter digital integrated circuit 74HCU04. It can output three signals of rectangular wave, triangle wave and sine wave at the same time. The signal frequency is continuously adjustable from 10Hz to 1MHz. A to F are six inverters, A and C1 form an integrator, and B, C, R2, and R3 form a Schmidt circuit. When the output signal of the Schmidt circuit is fed back to the input end of the integrator through R1 and RP1 , forming a square wave oscillator. The oscillation frequency can be approximated by the following formula: fosc=1/4 [(R1+RP1)C1](R3/R2). Adjusting RP1 can change fosc. If the minimum oscillation frequency is taken as 1, the oscillation frequency can be continuously adjusted in the range of 1 to 20 times. The relationship between the capacity of C1 and the oscillation frequency fosc is as shown in the attached table.
![Waveform generatorWaveform generator](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/9efc5215ab6d3ed0cada1ecf11398bb1.jpg)
F, R4, RP2, and R5 form a linear inverting circuit. Use four diodes VD1~VD4 to form a bridge. Limit the top of the triangle wave and convert it into a sine wave. Adjust the value of RP2 to minimize the distortion rate of the sine wave.
![Waveform generatorWaveform generator](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/2c4991601193c759fed5e79aa1308f68.jpg)
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- The main characteristics, advantages and disadvantages of IoT protocols
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- Eight-way remote control transmitter circuit using CS901
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- TR5100 FM 150~15 MHz transceiver
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- RXM-433/418/315-LC-P AM Receiver Module
- Stereo FM transmitter circuit designed with BH1417
- Square wave generation circuit
- Single tube TV antenna amplifier circuit
- TDA7010T+LM386 FM walkie-talkie circuit diagram
- Sample/hold (S/H) circuit diagram
- PLL FM demodulation composed of CD4046
- Duplex communication circuit composed of MCl45030
- Square wave and triangle wave oscillator circuit composed of 5532
- Personnel positioning system control module circuit design
- Using TC35I wireless data transmission and GSM communication module circuit design circuit diagram
- Infrared communication circuit diagram based on microcontroller
