Infrared communication circuit diagram based on microcontroller
Source: InternetPublisher:D先生 Keywords: wireless communication infrared communication Updated: 2021/09/09
The circuit introduced in this article was originally an actual circuit used for time correction and meter reading in a time-sharing electric meter. It's simple and practical. Using the asynchronous communication port of the microcontroller, using the infrared light transmitting tube sir-563 and the infrared light receiving ic tube rpm6938 to realize the function of receiving and sending point signals, the half-duplex two-way communication function can be realized. The communication distance is about 10 meters, and the asynchronous communication baud rate is 1200.
Circuit principle: The infrared sending circuit is composed of a 4001mos NOR gate 38khz oscillator, a serial port sending control gate circuit and an infrared light emitting tube sir-563 drive output circuit. When the serial port sending txd end of the microcontroller is '0', the infrared light emitting tube emits 38khz modulated infrared light. When the txd terminal is '1', the emission tube does not emit light. See Figure 1. The infrared receiving circuit is the infrared receiving specialized integrated circuit rpm6938. When receiving 38khz modulated infrared light, the output terminal of rpm6938 is '0', which is usually '1'. It can be connected with the microcontroller serial port transmitting and receiving terminal rxd.
- A cheap and easy-to-make infrared TV signal repeater
- Using 3DA87C to make FM transmitter circuit
- Pocket Wireless Microphone
- Homemade FM wireless microphone for teaching
- Convenient and practical telephone automatic redial controller
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- nRF401/nRF403433/315 MHz Transceiver
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- TX4930 FM/FSK 915/868/433 MHz Transmitter
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Square wave generation circuit
- BA1404 FM transmitter chip internal principle block diagram and application circuit diagram
- Circuit diagram of two wireless microphones made by 3DG12
- Frequency modulation (fm) waveform generator circuit diagram
- TEA1062 call circuit diagram
- 60Hz time base generator composed of MM5369
- Personnel positioning system control module circuit design
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
