Laptops switched to battery power
Source: InternetPublisher:aytwartoofyoroo Keywords: battery power laptop battery powered Updated: 2021/12/28
Thunder and lightning are frequent in summer, and laptops using AC power supply are prone to lightning strikes. For safety reasons, during thunderstorms, the computer has to be shut down frequently and the power plug unplugged. Frequent switching on and off is not only troublesome, but also shortens the life of the computer and may cause data loss.
If the computer is powered by a lead-acid battery, this problem can be easily solved.
Figure 1 shows the schematic diagram of a circuit powered by a battery.
The original alternating current power supply system of the machine has a rectified and stabilized output voltage of DC19V (3.15A); now it is changed to use two 12V 20Ah maintenance-free batteries connected in series to form a 24V 20Ah battery E for power supply. The connection must be added as shown in Figure 1 Only the voltage stabilizing circuit shown can be connected to the computer.
Principle: In Figure 1, one channel of 24v voltage is added to the Q1 collector through BX; the other channel is stabilized by the voltage stabilizing circuit composed of R1, W1, D1, Q2, and Q1, so that Q2 and Q1 are turned on one after another, and Q1 The emitter outputs a stable 19v (3.15A) voltage, which replaces the original AC regulated power supply and supplies power to the computer.
Among them, Q1 and Q2 are connected to form a Darlington tube; C1 is a filter capacitor, LED1 is a working indicator light, when the computer is working normally, LED1 emits light; V is a DC voltmeter with a range of only 50V.
When the circuit is working normally, the power consumption of Q1 is 16W. Therefore, a 10cmx10cmx0.3cm aluminum heat sink is added to the tube.
During use, pay attention to the indication of voltmeter V. When the voltage drops to 21V, recharge E in time.
![Laptops switch to battery-powered Linear regulator](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/22b42dc0b3057a552816fc4800f7019e.jpg)
- Energy-saving motorcycle rectifier regulator
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- How to use SBR to improve power conversion efficiency
- Current/voltage conversion circuit using current converter
- Dynamic power supply for power amplifier controlled by thyristor
- Integrated regulated power supply with continuously adjustable output voltage
- Design of electric vehicle charger
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- Use TL431 to make a simple charger circuit
- Cadmium nickel battery charging circuit composed of CD4040
- Car battery charger circuit diagram
- STR5412 power circuit
- DC 12V to AC 100V inverter power supply circuit design
- Portable device charging power circuit design
- EPSON PHOTO 830U printer power circuit
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Low voltage adjustable reference power circuit
- led drive power circuit
