TDA2030A subwoofer circuit diagram
Source: InternetPublisher:清宁时光 Keywords: Amplifiers power supplies and other power circuits Updated: 2021/04/12
The excellent performance of TDA2030A has made it popular among everyone for more than ten years. Many luxurious-looking active speakers, mid-range power amplifiers, and subwoofers also use TDA2030.
![TDA2030A subwoofer circuit diagram](http://www.eeworld.com.cn/circuit/upload/4c107cb35913d1a9c70f3f3280782002/cbb89c4d204305bffe8a2313385fc6f1.jpg)
TDA2030A is a mono power amplifier integrated circuit. To make a stereo amplifier, two TDA2030A must be used. TDA2030A has only five pins, positive power supply, negative power supply, forward input, reverse input and output. The heat sink of TDA2030A is connected to the negative pole. When using dual power supplies, the heat sink must not be short-circuited with the ground wire.
This power amplifier board uses dual 12V power supplies, and TDA2030A works in OCL mode. OCL means that the amplifier directly drives the speaker without audio input, output transformer and output coupling capacitor. OCL has the characteristics of good sound quality, good frequency response, and low cost. Commonly used power amplifier circuit types include OTL, BTL, and OCL circuits with the fewest components and the best sound quality.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- 220V Remote Load Monitor
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic circuit description of adjustable voltage regulator LM317
- Switching power supply circuit composition and function introduction of each part
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Homemade low-power UPS
- Homemade home inverter circuit diagram
- 90V/10A high power amplifier
- Voice compressor circuit
- TDA2030A subwoofer circuit diagram
- Clamp amplifier circuit diagram
- Cascade MMIC amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Basic Op Amp Differential Amplifier
- An FM transmitter overvoltage protection circuit diagram
