8W LED driver application circuit diagram (input voltage is 85 to 264V)
Source: InternetPublisher:蓝猫淘气 Keywords: led lighting LED circuit led drive application circuit Updated: 2021/07/24
The figure below shows the circuit schematic of the NCP1015 in an isolated 1 W-8 W range AC-DC LED lighting application. It is worth mentioning that NCP1015 can also be used for non-isolated (no high-frequency transformer in the circuit) AC-DC LED lighting applications in the 1 W-8 W range. A tapped inductor can be used in the circuit to improve the efficiency of MOSFET operation. duty cycle, and improve system energy efficiency and circuit performance.
![8W LED driver application circuit diagram (input voltage is 85 to 264V)](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/08aadac738b4b9171a66506843b0449c.jpg)
- Example of LED AC drive circuit
- Fire safety evacuation emergency signs
- Low cost LED automatic emergency light circuit
- Design and production of a practical electronic counting device
- Driving circuit for driving light-emitting diodes by IR53HD420
- Low illumination amplifier circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Resistor value selection circuit
- Colorimeter circuit
- Shock resistant soft start constant current LED lighting circuit
- Capacitor step-down LED drive circuit diagram using varistor
- Common double-tube energy-saving lamp circuit schematic diagram
- LED energy-saving lamp circuit principle circuit diagram
- Energy-saving household small neon light circuit production
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Automotive LED driver circuit diagram using LT3486
- LT3783 boost configuration driving LED circuit diagram
- R1211 driving white LED circuit diagram
- MIC2298 driving LED circuit diagram
- Constant current drive LED circuit based on LM2734
