MIC2298 driving LED circuit diagram
Source: InternetPublisher:司马缸砸光 Keywords: LED circuit circuit diagram WIDTH Updated: 2020/01/13
Micrellnc has launched the industry's largest and most powerful LED driver MIC 2298 for portable electronic devices . This device is a 7W high-efficiency step-up DC/DC converter packaged in a small 3mm×3mm MLF. The MLC2298 is designed for flash and flashlight lighting applications in mobile phones, personal digital assistants (PDAs) and digital cameras.
The MIC2298 is guaranteed to deliver 3.5A of conversion current. The brightness of its white LEDs can be dynamically controlled by applying a voltage or pulse-width modulation (PWM) signal to the brightness setting pin. When this integrated circuit operates at a fixed conversion frequency of 1MHz, the efficiency is above 86%. This high efficiency results in longer battery life, coupled with its ultra-small size, making Micrel's MIC2298 the best solution for driving high-brightness white LEDs in advanced mobile phones and PDA devices.
The MIC2298 solution requires only a small 2.2μH inductor and small ceramic capacitors, minimizing the size and cost of the solution. Its working input voltage range is 2.5~10V. MLC2298 driving LED circuit is shown in the figure.
ck="window.open(this.src)" alt="Click to see larger image" />
- Delayed gradual lighting with protection function
- DCD-1240 multifunctional rechargeable lighting
- Driving circuit for driving light-emitting diodes by IR53HD420
- Use NE555 to make a touch self-extinguishing table lamp
- Simple light-controlled street light circuit (7)
- Chandelier brightness controller circuit using thyristor
- Shock resistant soft start constant current LED lighting circuit
- Bedside lamp controller circuit
- 6-digit cathode fluorescent triode display circuit
- Reverse polarity drive circuit
- 8W LED driver application circuit diagram (input voltage is 85 to 264V)
- LA4461N power amplifier circuit diagram
- Solar water heater water automatic control circuit diagram
- HA1384 power amplifier circuit diagram
- Ringing switch start protection circuit diagram
- Automatic disconnect battery charger circuit diagram
- Crystal oscillator 80mW FM transmitter production circuit diagram
- CDll4CP logic block circuit diagram
- LT3783 boost configuration driver LED circuit
- NCP1200 driver LED circuit
